philips dect 1211 voip
hornsteve9
i brought this philips voip phone but i cannot seem to get it to work can anybody help thanks
RichSmol
Re: philips dect 1211 voip
You have not been added to the trial yet - hopefully i'll get round to adding you this afternoon. I'll post back here once i've added you and you should receive an email with details of the next steps.
puddy
I thought the philips phone was only skype type compatable and only works when plugged in to a usb socket on the computer.
Its just a hand held speaker and mic for use with software and is not a true sip to sip voip hardwired phone like the siemens 450,460 dect voip phone which can make and recieve calls with the computer switched off unlike the philips phone
puddy
equipment used/help offered
speedtouch 716wl v5 router
linksys PAP2-NA
Linksys SPA3000 uk spec
siemens 460 voip dect phone
Grandstream GXP2000
RichSmol
hornsteve9 - You've now be added to the trial so I suggets you give it a go and report back!
