iPhone setup for PlusNet VoIP - Help Required.
daveg6hni
Hi, I've just managed to get my iPhone to Connect & Dial out, but I can't hear it ringing or what the recipient says when they pick up.
Also my speech is broken up and delayed at the recipient.
Has anyone got their iPhone to work or can suggest what I'm doing wrong ?
Thanks.
I am using Siphon 2.2 on a iPhone mk1 running v3.0 firmware and jail broken.
Server = sip2.net.net
Proxy  = nat.plus.net:5082
Reg. Timeout = 3600
NAT = Enabled
Local Port = 5060
STUN = 0
Keep Alive Interval = 15
Codec G711 (u-law) = ON
Codec G711 (A-law) = ON
Codec G722            = OFF
Codec G722.1          = OFF
Codec GSM              = ON
Codec G729            = OFF
All other settings as default
mdean
Re: iPhone setup for PlusNet VoIP - Help Required.
Hi
just tested my Sip account on my iPhone 3G using Siphon 2.2 with the following setting without any problem on WiFi and 3G.
puddy
Quote from: daveg6hni
Try changing your server to
sip.plus.net
Puddy
ps Martin  I registered my Nokia phone on 3G and left it for a week , I then got text message telling me I had spent £10 on internet usage.
I thought that would be me browsing in the internet then 3 days later got another text message saying I used £20 on internet usage, I know I had not used the internet since the first message, turns out i did not switch off the 3G on my  nokia phone VoIP account ended up with an extra £25 bill.  In addition making 3G VoIP calls can work out more expensive than making a normal call or mobile call.
Please note  I made no VoIP 3G calls but leaving it registered it uses data and even if you get unlimited internet usage with your mobile contract 3G voip calls are outside of your mobile data plan check your terms and conditions its buried in their
