help - sj softphone wont work, is the problem its running on vista?
lr73
hi all! just joined plusnet and want to get my free calls but cannot get it working. used to be with orange and used the livebox which you just had to plug a normal phone into which was easy! also just getting used to using vista as last computer was xp which was easy! would i be better just buying a usb phone? what should i do? any help would be gratefully received. thanks in advance!
Valencia
Re: help - sj softphone wont work, is the problem its running on vista?
I had trouble with same, so I have bought a Linksys PAP2-NA "Unlocked Forever" version from Ebay on Puddy's advice, it cost less than £20 inc delivery, just plug your BT phone in and configure to Plusnet. Works with or without computer ON.
pcoventry
Hello,
I posted this a few weeks ago. There is a problem with the latest version but a version before overcomes the crash when attempting to initialise the profile.
Please see this short thread
http://community.plus.net/forum/index.php/topic,65492.0.html
lr73
no joy with sjphone so using pc phone from global ip. took 2mins to setup and works perfectly on vista.
http://www.globaliptel.com/eng/content/Products/Softphones/RTC/PCPhone.html
