broadband microfilter
Neciy
Hi I have moved and this house is not cable ready so I had to put a microfilter on however now I can not extend to reach where I wanted to set up the computer with external hard drive any suggestions will be most appreciated. I did find some products just not sure they will work on a tight budget so cant aford to waste money
http://www.mutek.co.uk/acatalog/Broadband_ADSL_extension_cable___in_stock.html
BT 5m Slim line Telephone - Broadband Extension Co
http://www.shop.bt.com/productview
puddy
Re: broadband microfilter
1.The easy way get BT to install a extra BT socket near your computer £60
2 Get a telephone extension cable fitted with a socket at the end and run it up to your computer you want to use less than £10
3. if you want to use your router at the master socket run a cat6 cable(best you can get) plug it into your filter downstairs and plug the other end in to your computer less than £15
4 Get a wirless router leave it at the master socket and install a network card in your computer (I got a speedtouch 780 wl router off ebay for less than £15) then let them talk to each other make sure any routers at least adsl 2+
puddy
paulby
You might want to keep this to your other thread here.
