broad band phone error
weavers4
support didnt know
can you help?
re payg brnatproxy, expired at 2011-10-04 08:48:18, logged into v-sip-1
NAT: 6550049 on v-nat-proxy-1 from 84.93.222.96 (84.93.222.96.homesurf.pth-ag2.dyn.plus.net), internal IP 84.93.222.96, until 2011-10-04 02:33:23oadband phone
jojopillo
Re: broad band phone error
Hi weavers4,
Are you not able to make/receive calls? When do you get this error?
Jojo Smiley
Fixes: 57
Note - duplicate thread removed
Fixes: 44
@weavers4,
I assume that's the status as shown on your voip control panel.
The
time is around the time of your post so it could just be that the control panel hadn't updated yet for the re-registration.
The NAT line showing the previous registration is a little odd though, you would have expected the internal IP to have bee one of your private ip's(192,168,x,x) rather than your public IP.
What does the control panel currently show ? and as Jojo says , can you make/receive calls ?
NB you might also wnat to redact the public IP's and your extension number details in the original post since this is a public forum.
