ZyXEL Prestige 2002L
civval
I have not been able to get my ZyXEL 2002L to register at all with the Plus Net service although it will register happily with my Sipgate Account.
My settings are:
SIP Number  xxxxxxxx
SIP Local Port  5060
SIP Server Address  sip2.plus.net
SIP Server Port  5060
REGISTER Server Address  sip2.plus.net
REGISTER Server Port  5060
SIP Service Domain  sip2.plus.net
Authentication User-ID  xxxxxxxxxx
Authentication Password  xxxxxxxxx
Has anyone else had similar problems that they have managed to resolve?
Fixes: 8
Re: ZyXEL Prestige 2002L
I got confused between the account password (which I changed as instructed) and the SIP/VoIP password which you change on the extensions page.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
scottiedog
Hi Civval
I had problems with my Zyxel box but only for SIP to SIP calls.
It registered all ok. The Authentication password I left as what Plusnet gave.
Settings are:
SIP Settings
    Active SIP - ticked
    SIP Number - xxxxxxx
    SIP Local Port    - 5060
    SIP Server Address - sip2.plus.net
    SIP Server Port - 5060
    REGISTER Server Address- sip2.plus.net
    REGISTER Server Port- 5060
    SIP Service Domain   - sip2.plus.net
Authentication
    User-ID  - xxxxxxx
    Password - ******
Advanced Settings
URL TYPE - SIP
Expiration Duration - 3600
Register Re-send timer - 180
Session Expires - 180
Min -SE - 30
RTP Port Range
From - 50000
To     - 65535
Voice Compression Type - G.711 > G.729
STUN
Not Active
Use NAT
Not Active
Outbound Proxy
Active ticked
Server Address - nat.plus.net
server port - 5082
NAT Keep Alive
Not Active
Echo Cancellation...G.168...Active
VAD Support...Active.
Depending if your router is a NAT router you may  need the outbound Proxy details, and if you have a SIP Application Layer Gateway, ALG. you will not?
I completed tests with Noel (fotobits) as we both have the Zyxel P2002L. Our setting differ slightly because of our routers but in general are the same. Might be worth posting all your Zyxel settings and Router settings as Plusnet might be able to point you in the right direction or other forum users.
You also have the active SIP 1 or 2 whichever ticked. It may also be your password, Pnet will be able to test it.
Regards
Scott
fotobits
civval, I've rather rushed these notes, as I've just got to go out.  However, I think they're correct, if not I'll look at them this evening.
If you find them clear, I'll submit them to PlusNet to put in their recommended settings.
Regards.....Noel
System - Time settings tab
Protocol :  Daytime (RFC-867)
Sever address :  time.windows.com
Ethernet tab
Get IP Address Automatically : select
VoIP tab
Active : select
SIP1 : select
SIP Number : enter your SIP ID No
SIP Local Port : 5060
SIP Server Address : sip2.plus.net
SIP Server Port : 5060
REGISTER Server Address : sip2.plus.net
REGISTER Server Port : 5060
SIP Service Domain : sip2.plus.net
Authentificatio User-ID : enter your SIP ID No
Authentification Password : enter your password to access PlusNet
Sending Caller ID : tick
Phone1 : tick
VoIP - Advanced settings tab
Leave all default values except.....
( I made Expiration Duration 1800, to re-register every 15-mins, you may prefer the default 3600)
Preferred Compression Type : G.711 only
Leave everything else unselected
DTMF Mode : RFC2833
Phone Port tab
SIP1 : tick
G.168 Active : tick
VAD Support : tick
Phone Book Lifeline tab
Create PSTN Pre-fix No as you require
fotobits
Yes, Civval, Scott is correct.  Some of my settings are because of my router and cannot be considered suitable as a standard for everyone.
Follow Scott's advice!
Regards....Noel
civval
Thanks for your help.  It seems to be working fine now.
I used Scott's settings with the Outbound Proxy ticked
