Zoom X6V modem and PlusNet
I wonder if anyone else uses this device. I have setup my PN VOIP service and it works using the instructions detailed here:- http://zoom.custhelp.com/cgi-bin/zoom.cfg/php/enduser/std_adp.php?p_faqid=1011
I have also changed the audio settings to ~ G.711A |G.711u | G.728B | iLBC.
Do I need to change anything in the Regionalization section for the SLAC and CODEC settings or any other section need any changes?
Many thanks
Dan.
1 REPLY
Re: Zoom X6V modem and PlusNet
To expand on my question, do I select
Belcore MDMF, Belcore SDMF, ETSI WINK, ETSI RING, DTMF in the SLAC Configuration and CODEC Configuration
I think ETSI RING but I would like this confirmed
Dan
