Would this work with plusnet VOIP
warbleeder
Sorry I can't post link as I'm on mobile but here's eBay item number
151370152005
I think it will work but wanna double check..this way I don't have to used a wired handset
Thanks in advance
pwatson
Re: Would this work with plusnet VOIP
The Linksys PAPT2 should be fine as it is a standard SIP ATA.  Note that the unit you've found is in China though.
warbleeder
There's loads on eBay... That was one I was looking at when I posted here... Smiley
Think I'm gonna go with that and just buy a cordless phone for it...
Fixes: 4
I believe other Plusnet customers do use Linksys PAP2T.
However -
  • That item is coming from China so you don't know whether it is a fake.
  • That price is about the going rate for these secondhand or 'like new' from UK sellers, so it isn't a bargain price.
  • When buying "PAP2T" ensure that is "Unlocked" (like the one listed), as many on eBay are locked to "Vonage".
  • I would be wary of that part number ending in "-NA",
    as that often indicates only for use in North America that use a different telephone system !
    You should be looking for one that ends in "-UK" to be compatible with BT line characteristics.
So NO,  I wouldn't buy that !  Cry
warbleeder
Wouldn't the N.A and u.k be due to firmware. Not hardware... As I know this is the case with netgear
Fixes: 4
I don't know whether there are hardware implications between the UK and NA models.
Some sites say -
Port Impedance Eight Configurable Setting Including North America 600 ohms, European CTR21
Ring Voltage 60 - 90 Vrms
Whether the ring voltages, line impedance, and ring capacitors are software selectable, or are different hardware versions, you need to check before you buy.
With a quick google you can find sellers that state -
[quote=http://www.play.com/PC/PCs/4-/32935074/1023932529/-/ListingDetails.html?gclid=CICV0qCSyMICFa_JtAodEnMA3Q&_%24ja=tsid:13315|cat:32935074|prd:32935074&$$ja=cgid:14882800617|tsid:48121|cid:269896737|lid:86992636617|nw:g|crid:49114428657|rnd:8926275016111846494|dvc:c|adp:1o8|mt:|bku:1]Linksys PAP2T VoIP Gateway EU power adapter. Not to be used in the UK with 2 ports for Voice-over-IP
which seems to be an unusual statement if you were going on the assumption that this was a universal device with software selectable interface characteristics.
