Working Settings for PlusTalk BETA on Nokia N82 (should also work on N95)
sourceit
Hi
After much waiting and trying different settings, I finally have my Nokia N82 working on PlusTalk VoIP Trial.  Here are my settings:-
Profile Name: Gradwell
Service Profile: IETF
Default Access Point: <my wireless AP name>
Public User name: sip:<sipnumber>@sip2.plus.net
Use compression: No
Registration: Always on
Use Security: No
Proxy Server
Proxy Server Address: sip:nat.plus.net
Realm: sip2.plus.net
username: <your sip number>
password: <your sip password as set on beta website>
Allow loose routing: Yes
Transport Type: UDP
Port: 5082
Registrar Server
Regsitrar server address: sip:sip2.plus.net
Username: <your sip user id>
Password: <your sip password>
Transport Type: UDP
Port: 5060
I hope this helps someone else trying to set this up as it was driving me mad!
Regards
Ben Grin
puddy
Re: Working Settings for PlusTalk BETA on Nokia N82 (should also work on N95)
I have just ordered a Nokia E65 so hopefully it will get here before the weekend I will give it ago!
Puddy
puddy
Quote from: Source
Regards
Ben Grin
Worked a treat on my Nokia E65
Puddy
puddy
also works on my mrs n95 with a tick in disabled anonymous calls  Its in call barring settings under internet call barring same tick needed on nokia n82 as well
puddy
