Why does my usage show broadband phone
Fixes: 13
Why does my usage show 1% usage on broadband phone, when I do not have broadband phone? Shocked Shocked Shocked
Fixes: 117
Re: Why does my usage show broadband phone
Probably misidentified traffic more than anything..
Will Moderate For Thanks
Fixes: 13
Perhaps PN should have a special line for that then!
"Err sorry, we can`t think of where to put this useage, as we don`t know what you were doing at the time!    1%  Roll eyes
Fixes: 117
How much is your 1%? I have more listed under other than phone - and I use it  Smiley
Fixes: 13
I don`t know !  1%  I suppose !!!  but it is listed as 1% of my "paid for usage".... so if the figure rises, then my "paid for " allowance drops... and If I don`t have Broadband phone, and PN don`t know what it was, then why should I be penalised?..... I can`t reduce the "unknown" usage, if I don`t know what it is in the first place.... (It`s not significant at present, nor likely to be.... just the principle of the thing.)  Undecided
pierre_pierre
Its what they call elacoya drift.  But it is wise to keep an eye on it 22 Oct the system had a deplorable hickup and some got several Gigs of fake postings
Fixes: 13
Cheers Pierre, will do !  Roll eyes
prichardson
It is indeed the case that usage attributed to Broadband Phone has come from your paid allowance, however you need to be aware that you have not been penalised.
The usage has simply been mis-classified by type, not by volume. Had we attributed the traffic to the correct type, it would still have come from your account usage (paid usage), just a different category.
Quote from: pierre_pierre
Hmm, I like that.  Well coined phrase, Pierre Wink
B.
