When Are Broadband Phone Free Minutes Reset?
I've just started my new billing month but my Broadband Phone free minutes haven't been reset.
Are these reset in line with the PlusNet billing cycle or on the monthly anniversary of when the Broadband Phone service was activated?
Thanks - Bob
Fixes: 116
Re: When Are Broadband Phone Free Minutes Reset?
Mine tick over on the same day as my broadband does.
Will Moderate For Thanks
Fixes: 43
They should be reset in line with your normal billing cycle.
Thanks, I'll give it 24 hours and then raise a ticket if they still haven't been reset.
Bob
itsme
Mine reset on my original billing date which is now different to my current billing date as I changed BB package and my billing date was moved.
Please could one of the Comms Team clarify what should happen.
Bob
James
Hi Bob,
It should be on your broadband billing date, unless this has been changed since you activated your VoIP service with us.
puddy
in the past plusnet have not always re-set the free minutes on some account, I thought they had fixed it issue
you may have to raise a ticket
puddy
Yes, I've raised a ticket and it's been passed to Gradwell.
Bob
For info. this is the response to my ticket:
"Dear Mr Boulby,
This is the response from the Gradwell tech team:
Our server team has advised the minutes will not be reset until the next billing date which is the 18th of April.
The first month is a long month and the minutes given are adjusted"
Bob
