What is Jabber and how do I get the settings
equiroma
I have almost driven myself insane trying to set up the SJ Phone on my computer, all I want to do is set the thing up but alas everything I try to figure out is too complicated as I am a complete beginner on this. The softphone is asking "Please specify your Jabber connection options" No clue!!!!!! It is also telling me that PlusNet VoIP Service unavailable and Authentication failed. Please please somebody help, I am soooo confused with all this. PS I followed the setup guide to the letter.
Fixes: 69
Re: What is Jabber and how do I get the settings
Jabber is an Instant Messaging protocol, we actually use it here at Plusnet Towers to communicate with one another.
Have you tried X-Lite to see if you have any more success with that?
Plusnet Products Team
equiroma
Not yet but I will, I will let you know how I get on with it but any ideas on why the SJ wont work? Thank you
Simon_M
Quote from: Bob
That page badly needs a re-write. Xten were renamed Counterpath a long time ago & X-Lite is now based on Bria, rather than eyeBeam.
It also suggests that there is a problem with the 'current' version of X-Lite. I suspect that refers to a long replaced version. The current version works fine with Gradwell/Plusnet.
The download link for X-Lite should read  http://www.counterpath.com/x-lite-download.html
