Voip account association on Portal
Just something I noticed this evening.
On the portal under "my accounts" and then "broadband phone" I'd noticed that my pre-trial SIP account is associated with the portal and not my new trial (Which I guess isn't a trial any more) SIP account..
Obviously, going to voip.plus.net shows the correct information with the correct amount of credit and calls made/recieved.
Can someone take a look.
Cheers
Roger.
RichSmol
Re: Voip account association on Portal
There is a plan afoot to fix the portal and to allow synchronous login into voip.plus.net once your into the member centre. The voip.plus.net is kinda stand alone at the moment - which is why we have to do credit top ups manually and things like that - will be automated and shiny at some point during November.
Thanks Rich,
I thought that was going to be the case, however, it always pays to ask the question!!
Roger.
