Voip Control Panel
Fixes: 41
Voip Control Panel
Anyone else having problems with the Voip control panel ?.
Just looked at mine and it seems to have lost the call data for March and April.
Logged out and tried to login again and now not responding at all...
Gradwell had a service status on the 10th saying having problem with control panel but said fixed later that day.
Edit: OK , forget that chaps ( and chapesses! ) it seems to be working again. At least, its got March data back , although no April calls and I'm sure I made one yesterday!
Re: Voip Control Panel
Yes, mine was messed up as well this morning but is ok now. The only exception seems to be that calls aren't appearing straight away in the calls out list.
Bob
Fixes: 41
Cheers Bob,  thought I was going mad for a moment there!!
Yesterdays call has now appeared.
