VoIP voicemail not storing messages
Fixes: 8
Incoming calls where it diverts to voicemail (e.g. VoIP software not running because PC turned off) are generating The "New Voicemail message received" email with the voice message attached, but the message is not being stored on the system. The softphone isn't saying messages waiting, *1 says no messages and looking in the VoIP control panel there are no messages.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 117
Re: VoIP voicemail not storing messages
just tested it here.. getting the emails, i can see the message in the voip panel and message is stored can call to pick it up.
no voicemail indicator showing though.
Will Moderate For Thanks
Fixes: 117
just got the voicemail notification to my phone, so about 45 minutes after the message was left.
Fixes: 8
I left two test messages this morning for which notification eventually appeared in X-lite a considerable time after I'd received the email.
How quickly did the messages appear in the VoIP control panel for you?
I'm sure it never used to be as slow as this!
Edit: when I first looked in the panel and found they were not there I tried the Update VoiceMail Data link.
Fixes: 117
it did use to be instant, certainly not as slow as today.
the refresh in the panel showed the message straight away.
Fixes: 70
I notice Gradwell have had a few issues with Voicemail recently.
Plusnet Products Team
