VoIP down?
Fixes: 8
VoIP down?
I'm getting SIP error 503
There's nothing on the Gradwell status page.
Anyone else having problems?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 8
Re: VoIP down?
Ticket 64823434 following call to CSC
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: VoIP down?
My account's registered without issue, I can't test making a call as I've got no credit though!
 Chris Parr
 Plusnet Staff
Fixes: 8
Re: VoIP down?
Just tried 3CX phone (lucky I had it installed from investigating the traffic management issues when using X-lite!) and that connected.
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: VoIP down?
http://www.gradwellstatus.com/viewpost.php?id=487
Just posted on Gradwell's site.
 Chris Parr
 Plusnet Staff
Fixes: 8
Re: VoIP down?
They cleared that shortly after you posted but it looks like it's down again
Fixes: 8
Re: VoIP down?
It's back again now - was off for at least 5 minutes.
Fixes: 8
Re: VoIP down?
I don't know what's going on but it's going up and down like the proverbial whore's knickers!
mattturner
Re: VoIP down?
Hi Jelv,
Seems like there are some problems at the moment, the problem this morning that we thought was fixed aparently isnt not, as you've seen!
We've just had this notification from Gradwell and will keep you updated.
-----Original Message-----
From: Gradwell Status [mailto:support@gradwell.com]
Sent: 22 January 2013 14:34
Subject: [gwStatus] New Service Post: Partner intermittent Call/Registrations Issue
Title: Partner intermittent Call/Registrations Issue
Event: A new service post has been created.
Brief:
We are currently seeing intermittent failures to call and register due to failing DNS queries.
Impact:
Partners may see phones sporadically unable to make and receive phone calls, and also failure to register phones. This will only be affecting Partners and not direct customers of Gradwell.
Action:
We have identified the root cause and we are currently working on a solution for this.
We aim to provide the next update by Tuesday 22nd January 2013 @ 16:00 (GMT)
For further information visit http://g--s.net/488
Thank you,
Gradwell Status
If you wish to unsubscribe from Gradwell Status notifications, you can do so here: http://www.gradwellstatus.com/unsubscribe.php
Fixes: 8
Re: VoIP down?
Thanks for that. I've seen their update about removing a DNS server from service and it is looking a lot more stable.
RPMozley
Re: VoIP down?
I'm getting registration timeouts at the moment - 3CX phone on iPod touch. Specifically on the 'Out of Office' or 'External PBX' it appears to be failing on.
Gradwell still not fixed the issue?
Edit: Working currently, so must be an intermittent error.
That's RPM to you!!
Fixes: 117
Re: VoIP down?
mine doesn't seem to have dropped at all during the day.
Will Moderate For Thanks
