VoIP and FTTC (Fibre Optic) - what chance / kit / pitfalls?
PNet4um
I have a friend who is an ex-NTL(Virgin) customer looking to switch BB supplier and is considering FTTC (Fibre) at the same time.
One thing that he knows that I enthuse about is VoIP - partly to avoid Mobile charges (especially abroad) - so that raises the questions:
1. Does Plusnet offer both VoIP and Fibre Optic in a package?
2. If they don't - is it likely to work and what are the potential problem(s)
3. He has a Smartphone (w/WiFi) capable of using Fring BUT he would probably want to have a landline OR? cordless phone plugged into a router - what sort of kit would anyone recommend? or failing that - what might work on paper?! There don't seem to be reasonably priced NON-ADSL Routers that "DO" VoIP unless I have been looking in the wrong places.
I did search the forums before posting - is there no-one contemplating this? That would be a worry in it's own right!
Just as a final thought - from memory - the BT Homehub has VoIP capability I THINK... I presume their (BT) equivalent for FTTC has the same... Is the BT Homehub locked to the BT! VoIP service and if so - what are the equivalent boxes in that scenario?
Fixes: 113
Re: VoIP and FTTC (Fibre Optic) - what chance / kit / pitfalls?
I use voip and fibre with no problems at all.  There isn't an all in one package but you can get it as an add on.
Fring does work with the pn voip service which is provided by gradwell.
Will Moderate For Thanks
itsme
The Fibre compatible Homehub I believe no longer support VoIP but the Business hub does. The older versions of the Business hub have a hack to configure non-BT VoIP but don't know whether it will work on the latest fibre compatible Business hub.
PNet4um
Quote from: dvorak
What hardware do you use? I was hoping to use a cheap-ish router w/WiFi and VoIP but do I need two boxes now?
Fixes: 113
I've used a couple of handsets, an old grandstream 100 which I picked up from ebay for around 20 quid before I invested in a slightly more expensive yealink tp20.
Both easy to set up and use with the service. Also had a nokia n95 and android phones working with it.
You don't necessarily need a router that has built in voip in to use the service.
Certainly not cheap but this one 'does it all': http://www.avm.de/en/Produkte/FRITZBox/FRITZ_Box_Fon_WLAN_7390/index.php
Call me 'w23'
