VoIP Number Not Recognised
itsme
Is it just me or is there a wider problem out there that for incoming VoIP calls the caller hear the BT announcement
'The number you have dialled has not been recognised please check and try again'
Re: VoIP Number Not Recognised
Just tested and mine's working ok.
Bob.
Owain
May depend on which area code your dial-in number uses, as there's been a major fault with a BT network node in London - http://news.bbc.co.uk/1/hi/technology/8598371.stm
itsme
I'm hoping it is this outage that causing the problem. If it is than I expect others to be experiencing the same. If it just me and I have to raise a fault with PN it could take several days/weeks for PN to fix.
