Vigor 2710Vn
withinlea
Vigor 2710Vn
I have tried always to fill in this form. I had no problems before on other systems, even set up my Nokia for Voip, but this I just can get to register, any help would be great.
Fixes: 41
Re: Vigor 2710Vn
OK, let's give it a try:-
Profile name - anything you like e.g PlusNet
Register via - Auto
Domain/Realm - sip.plus.net
Proxy - nat.plus.net:5082
Display name - anything you like e.g typically phone number
Account number - <your 7 digit sip id>
Authentication ID - empty , Authentication ID box should be unchecked
Password - <your sip password>
Leave everything else as is for now.
Give that a try, and post back with the results
withinlea
Re: Vigor 2710Vn
Thank you MisterW. The only thing that I hadn't tried was the Register Via Auto. The set is now registered.
Cheers
Fixes: 41
Re: Vigor 2710Vn
Yes, I wasn't sure about that so I downloaded the manual.
