VOIP
jimbo121
VOIP
Hi, does anybody know if Voip calls that originate from Europe are all routed thru a London exchange ie, area code 020, cheers.
Fixes: 8
Re: VOIP
Are you asking about VoIP to VoIP, EU landline to UK VoIP or EU VoIP to UK landline?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
jimbo121
Re: VOIP
Hi, it would be EU VoIP to UK landline, thanks for your interest, Regards jim
Fixes: 8
Re: VOIP
I think you'd have to direct that question to the VoIP provider - it is likely to vary by provider.
jimbo121
Re: VOIP
Thanks for your help,Regards jim
