VOIP trial
kevinhenry
VOIP trial
I have signed up for the VOIP trial and have been allocated an 01273 number, I set up my Planet VIP-156 ATA and outgong calls work fine but any incoming calls are presented with a recorded message saying that this number is temporialy out of service.
Any ideas?
Thanks,
Kevin henry.
1 REPLY
RichSmol
Re: VOIP trial
I've notified Gradwell as I've seen a couple of these over the past day or 2. Its possible you may have a completely new number which has not yet been added to the telco dial plans. One call to the telcos usually sorts it out. I'll let you know when I hear something back from Gradwell.
cheers
Rich
