VOIP problem!
Scotty1
VOIP problem!
Hello!
I'm new to this forum so I hope someone can help!
I have been in contact with plusnet support regarding a port problem. I have been trying to connect a work phone from home to allow my Fiancee to work remotely. It did work but stopped about 4 weeks ago. As far as i can tell the ports that I need are being blocked. I have forwarded the ports on my router to the phone manually and then  again by using PFconfig as suggested buy plusnet. PFcheck confirms that they are still blocked!!  Angry
Plusnet have confirmed that my broadband firewall is off so I'm now at a bit of a loss.
I have a Netgear DGFV338 router and the phone is a Grandstream GPX2000. It is connected directly to one of the router ports.
Ports ranges that I need are 4569,5004-5089 (TCP and UDP) and 10000-20000
Any advice, greatly recieved!!
Fixes: 8
Re: VOIP problem!
Have you done a disconnect/reconnect of the router since the firewall was set to off?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Scotty1
Re: VOIP problem!
Thanks for replying jelv
Yes I have. In-fact I de-powered both the router and phone for a good 20mins last night and then let the router come up and connect before re-powering the phone.
Still didn't solve the problem though!
Fixes: 69
Re: VOIP problem!
Quote from: Scotty1
So something like this also reports the ports to be closed. If it does then it pretty much has to be a router/port forwarding configuration error. Does the router itself have any IP filtering/firewall and if it does what happens if you temporarily disable that?
Plusnet Products Team
Scotty1
Re: VOIP problem!
Thanks Bob
Just tried that link and yes, it reports the ports as closed.
NAT is turned on but I have tried turning it off (classic routing) and still no joy. I have also tried putting the phone in a DMZ. Same problem!!!
Fixes: 43
Re: VOIP problem!
That sounds like it maybe a problem with your voip account rather than ports being blocked, have you checked that your voip account still works with a softphone ?
TBH you shouldn't need to do any port forwarding if you've got the GXP configured correctly. Make sure the outbound proxy is set correctly ( nat.plus.net:5082 ), the Nat Traversal is set to Yes and No Stun server is specified.
