VOIP devices failing to register
pnf
My various VOIP devices have all failed to register with the service since yesterday.
I notice that Gradwell are / have been carrying out work classified as low impact, could this be the source of the problem?
"Blade server upgrades (13/07/2014)
Thursday 10th, 15:43 - Monday 14th July 2014, 10:00 (BST)
Affecting VoIP, Web Hosting, Email Hosting
Impact Level: Low"
Fixes: 114
Re: VOIP devices failing to register
No issues here with it.
Will Moderate For Thanks
pnf
Thanks dvorak, that's interesting to know.  I shall have to raise a ticket.
pnf
I've resolved the issue.
I logged into the VOIP Control Panel and noticed that the line had last registered on 11th July.  This coincided with the last time that my Internet connection was established (IP address 84.93.xxx.xxx).
A short while ago, from my router, I dropped the Internet connection, waited a short time and then connected again to obtain a different IP address and this time the VOIP connection registered correctly.
Conclusion:  for some reason, the VOIP connection would not register on an IP address in the range 84.93.xxx.xxx.
Fixes: 69
There's is an ACL configured for Broadband Phone that restricts certain access based on IP. I've checked the ACL list though and 84.92.0.0/15 is present which encompasses the IP you were assigned when you had problems.
One to keep an eye on. Shout up if it happens again.
Plusnet Products Team
pnf
Thanks Bob.  I'll let you know if it happens again.
mview
Well, I seem to have a similar problem.  I've had a stable connection via my Gigaset N300 for months (years?).  Yesterday,  I noticed that it was reporting "Registration Failed"  -- I've made no changes to the config.  I can still connect to the service and make/receive calls via my Android phone, but the Gigaset persistently says no.
[edited:  re-booting my router solved the problem.  Hmm.  With regard to the discussion above, I have  a static IP, so that wasn' the issue.  Everything else was working just fine.]
Fixes: 15
I'm getting the same yesterday/today.
I had to reboot my HH2 (that does my voip) to plug in a fan yesterday. Since then it has been unable to register, just sits with the orange light on, occasional flashing as it tries to register.
Fixes: 114
csip simple is still still registering ok - but I've not restarted anything.
Fixes: 69
Different subnet, so these issues don't seem to be pointing to the IP. Little hard to replicate here though given that we've no access to your SIP login credentials. Not that it helps, but my account seems to be registering OK. No open service status threads over at Gradwell. Worth a password reset do you think? If that doesn't work then I'd suggest raising a support ticket so taht we can look into it.
Fixes: 15
Mine only happened after a drop reconnect of the voip client. It had been connected solidly for ages before this, even over router reboots (which my 589 seems to want to do daily  Crazy)
Will open a ticket.
Ticket open (88871226) with a 2 day response time  Cry
Fixes: 15
Well 2 days later no response, and still no connection  Cry
Fixes: 69
I've just responded to the ticket.
Fixes: 15
Still not registering Bob. Changed as suggested.
EDIT: Now connected. Thanks.
