VOIP SIP IP ATA Adapter. Can anyone advise?
juliasdream
I just bought a Pluscom VOIP SIP IP ATA Adapter to use with 12VOIP
In order to use it I need settings from 12VOIP
On their website I can only find setup info for USB handset/headset or speakers/mic
I need to program the box which will work independently from the computer connecting directly to my router
I wrote an email to 12VOIP ages ago and they didn't respond
I know from experience that they are useless when it comes to communicating with customers
Can anyone advise on what to do or where to get the info I need?
RichSmol
Re: VOIP SIP IP ATA Adapter. Can anyone advise?
I'd suggest that you post this in the VoIP trial forum - the following thread relates to hardware setup guides for the trial but you may be able to get some useful info out of it. If not, add your post to the thread and someone will help you - we have ~550 trial users using over 35 different types of hardware so the chances are good!
http://community.plus.net/forum/index.php/topic,57674.0.html
Moved to VOIP Trial board.
