Using BT Homehub with Plusnet broadband phone/voip
mortod
Is it possible to use the bt homehub (2) phone, or a phone plugged into the hub with the plusnet voip service?
Fixes: 117
Re: Using BT Homehub with Plusnet broadband phone/voip
Possibly, with some hacks have a look here http://www.homehubhacks.co.uk/index.php?n=HHH.Firmware
Will Moderate For Thanks
mortod
Hmmm - think those hacks only apply to earlier homehubs. I'm unable to telnet into mine, and the backup file is bin format, not text, so neither approach looks workable. But I guess my main question is answered - it is not possible to use the homehub to connect to Plusnet Voip, at least not without a hack which isn't possible on the v2.0.
