Upgrade to FTC with VOIP
colinallinson
I am currently a Plusnet user with standard DSL but FTC is now available in my area. However, I am a heavy VOIP user with multiple accounts. I use a AVM Fritz 7270 which collects calls from multiple VOIP accounts and, in addition, it has a phone connection to the landline to collect these calls as well. The effect is that one set of phones (connected to the Fritz) is used for both landline and VOIP calls.  VOIP calls are useful to me because I also receive and make outgoing calls to Germany with a German VOIP account that is configured into my Fritz box.
The Fritz box can be configured as just a router but this raises the following questions :-
1) Would the 7270 be useable as my own router (it does not support VDSL)?
2) If the 7270 is not suitable - would the VDSL equivalent (7390) be suitable?
3) Does the BT Fibre modem block SIP protocols (I had this problem with the PLUSNET supplied Thompson Modem with VOIP equipmentr behind it).
4) If I upgrade and can't get VOIP working properly - can they downgrade me again?
Or - Should I just leave alone for now?
Fixes: 41
Re: Upgrade to FTC with VOIP
Well the manual claims it can be connected to a DSL modem so it should be capable of being used with the BT modem.
Yes, there are a number of people who have used the 7390 directly connected to the VDSL line ( without the BT modem )
although this is not supported by BT/PlusNet.
No, its just a modem, it doesnt block anything.
Pass, you need one of the DC team to answer that.
Hope that helps.
Quote from: colinallinson
VOIP should work perfectly on FTTC, mine does!
Call me 'w23'
knowdice
And mine  Cheesy
itsme
You set the 7270 as per http://service.avm.de/support/en/skb/FRITZ-Box-7270-int/700:Connecting-FRITZ-Box-to-a-cable-modem the BT modem will plug into LAN 1 port
colinallinson
Thanks all for your help. That gives me a certain amount of confidence and I will look into it further when I get back in 2 weeks.
Fixes: 111
Just to add another voice to the list that VoIP on FTTC works fine.
Will Moderate For Thanks
