Two mailboxes?
Fixes: 8
Two mailboxes?
Could someone explain the reason for the two different extension/mailbox numbers shown on my account and how they are used?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
xpcomputers
Re: Two mailboxes?
I had this for a while too...
I think it was created by the fact that you were in the beta trial, so that created your Gradwell account & mailbox.
Then when the trial finished and  the old plustalk voip accounts got "gradwell-ised", this added the second mailbox to your account. This would have been especially true if you were transferring over your 0845 number.
When I opened a thread about this, the result was they deleted my second mailbox.
Mike
Fixes: 8
Re: Two mailboxes?
No wonder I couldn't figure out what it was for!
Fixes: 70
Re: Two mailboxes?
Quote from: xpcomputers
Don't think this happened in all cases (perhaps it's like you say and it was only where the 0845 number was transferred)
I know I only have one mailbox on my account.
Plusnet Products Team
RichSmol
Re: Two mailboxes?
yeh this was part of the migration - we migrated your old voip details and created a new one so you could authenticate against both. We probably need to do a mop up on extensions which havent been authenticated against since the migration a few months back. I've removed the extensions starting with a 4 so you just get the single extension on the extension view now.
cheers
Rich
Fixes: 8
Re: Two mailboxes?
