Two PC's running same account?
Quick question, I have two pc's which I could do with using the same PN VoIP account. I'm just wondering what would happen if both machines were running SJ at the same time using the same account details?
Fixes: 117
Re: Two PC's running same account?
well it works, I've done it Smiley
Will Moderate For Thanks
Fixes: 44
Yep, as Adie says, should work fine!.
Both will ring on an incoming call, first to answer will get the call.
You should be able to make outgoing calls from both at the same time( or one incoming and one outgoing ).
nice just what i need Cool btw any1 else get a virus warning with sj soft phone?  I get unknowm malware an icon file,got sj from official site
Fixes: 117
Not on Mac or XP
