Trust ST 1200 USB Adapter
Guthlac
No doubt a very basic question but I am only just starting to use the VoIP allowance I have with my account. Does anyone know if the Trust ST 1200 USB adapter would be suitable for connecting an existing phone to the computer?
I know I would still have to dial numbers via the computer keyboard but want to use a traditional handest (of which we have many). I am aware that the above unit would need an adapter for the BT plug as it comes with RJ11 sockets.
Any help or advice greatly appreciated.
Fixes: 43
Re: Trust ST 1200 USB Adapter
NO , it will only work with Skype. It is not SIP compatible.
Have a look at this http://www.voip-info.org/wiki/view/Analog+Telephone+Adapters for general info on voip adapters.
Granstream, Linksys/Sipura and Zoom have a range of fairly cheap ATA's that will work with Plusnet.
If you wish to use the phone as a dual phone i.e to make and receive calls via PSTN & Voip then you need an ATA with an FXO ( PSTN line) port as well as one or more FXS ( telephone) ports. I dont have a specific experience of any of the ATA's I'm afraid ( other than helping other on the forums to set them up ) as I use a Siemens DECT IP phone. Similar in function to an ATA  but it combines this with a DECT base station and handsets. Great if like me you needed to replace an ageing DECT phone anyway but not a cheap solution ( £60->£100+) if you already have some normal handsets around..
Shout up if you have more questions.
Fixes: 43
BTW here's a useful link so you can see more info and typical prices for ATA's
http://www.broadbandbuyer.co.uk/default_ShopGroup.asp?ShopGroupID=96
Guthlac
Thanks guys for the info and links. The seller on eBay "thought"  it might work but his wording left me in doubt; glad I checked here.
I only want to use the handset for VoIP so will check out the links in detail. Thanks again.
Guthlac
Amazon via one of their sellers have the Linksys/Supura at a very good price so am giving this a go. The link pages you gave have been helpful and interesting.
Fixes: 43
If  that's the SPA 2100 at £14.99 that looks VERY ( too ) cheap.
Have you seen this thread http://community.plus.net/forum/index.php/topic,72944.0.html
Fixes: 43
If it is that company ( Trusted Goods ) then they are advertising the same units on ebay at £22.99
http://cgi.ebay.co.uk/LINKSYS-SPA-2100-VOIP-PHONE-ADAPTER-SIP-NEW-UNLOCKED_W0QQitemZ290291060386QQcm...
but at least they do say here that its UNLOCKED
Guthlac
Yes it's the same one. Thanks for your input as you could have saved me some money. Strange it is cheaper via Amazon. I Trusted Goods a question last evening and have had no reply as yet. From experience, I find I usually get a reply within 24 hours or not at all which, then sets alarm bells ringing and I find another seller.
Looks like I am going to be using the headset for a while whilst I go into this in a bit more depth. I am in no desperate rush but want to get something reliable and fairly easy to set up.
Thanks again for the advice.
