Trixbox Voip Setup
mcgurka
Trixbox Voip Setup
Im playing about with the new voip trials on my trixbox, but I am having serious issues with it!
It registers, but nothing more. Heres the config Im using...
PEER Details:
allow=alaw&ulaw&g729
authuser=NNNNNN
canreinvite=yes
context=ext-did
disable=all
dtmfmode=info
fromdomain=sip2.plus.net
fromuser=NNNNNN
host=sip2.plus.net
insecure=very
qualify=yes
secret=PPPPPP
srvlookup=yes
type=friend
username=NNNNNN
Register String: NNNNNNTonguePPPPP@sip2.plus.net/NNNNNN
Any ideas?
RichSmol
Re: Trixbox Voip Setup
can anyone help out here? I'm afraid that I cant find any config data for this piece of kit.
I have found a Trixbox forum though which might be of use - might be worth a look?
http://www.trixbox.org/forums/help
mcgurka
Just an update for you, I may have found a config file for it, but I cant test it, due to my connection being far to latent (see community support - Ping times)
I do get calls inbound (sometimes) and can make outbound calls. I will post my config file up once my connection is sorted and I can be sure it works OK.
mcgurka
Rich, If you want it, I will PM you successful config steps to get the system to work with asterisk / trixbox?
Scott
Docrob
Here are my settings for asterix/sail pbx running on a SME server:
type=peer
host=sip2.plus.net
ouboundproxy=nat.plus.net
outboundport=5082
qualify=3000
canreinvite=no
insecure=very
authuser=NNNNN
username=NNNNN
fromuser=NNNNN
secret=PPPPP
disallow=all
allow=alaw
allow=ulaw
The reg string is:
NNNNNTonguePPPP@sip2.plus.net/NNNNN
I also needed to setup and inbound trunk route too.
Hope this may help someone.
Rob
