Tesco DP450 or Siemens DP450
beetman
Hi This phone has work great since "bobboulby" sorted me BUT now since the plusnet change of IP settings I have failed to get the phone to register, followed the instructions but no go!! Do I need Static IP or automatic? if static what are the following setting/ have they changed?
IP address:  .  .  .
Subnet mask:  .  .  .
Default gateway:  .  .  .
Preferred DNS server:  .  .  .
or am I barking ------ up the wrong tree?
Please help
Chris
Fixes: 41
Re: Tesco DP450 or Siemens DP450
What Plus net change of IP settings ?
The only thing that's changed recently is that if you were using natproxy.plus.net  you need to change to nat.plus.net
beetman
Hi, Yes that's the change, but I was using sip.plus.net and the day before yesterday I lost provider registration so changed it to nat.plus.net port 5082 but still will not register?
I assumed that the sip/nat change was what has caused the problem!!
Chris
It's only the Outbound Proxy that's changed.
Proxy:sip.plus.net
Outbound Proxy: nat.plus.net
Works here - using a Linksys Sipura SPA adapter.
beetman
Thank you jaggies, outbound poxy was wrong, now working great again.
Wonderful forum for thickies like me!
Thank you all
