SvSIP? SIP Phone for Nintendo DS.
YuJay
http://svsip.free.fr
any one here happen to have SvSIP working with Plusnet SIP phone?
so far i can ring out but not speak.
this is the config options.
# This is a comment in the config file.
# Information on http://svsip.free.fr
# Set domain sip provider (example: freephonie.net)
--domain sip.plus.net
# Set authentication username
--username XXXXXXX
# Set authentication password
--password XXXXXXXX
# Optional registration interval (default 55) (for freephonie set 1800)
--reg-timeout 1800
# Optional microphone volume (default 1.0)
--mic-level 3.0
# Optional speaker volume (default 1.0)
#--speaker-level 1.0
# Optional for expert: set realm
--realm sip.plus.net
#optional:  log to filename
#--log-file directory/filename
# optional: set log max level to N (0(none) to 6(trace))
#--log-level
# Enable ICE (default:no)
#--use-ice
# Add the specified nameserver to enable SRV resolution
# This option can be specified multiple times.
#--nameserver XXXXXXXX
any can make head or tails of this? Smiley
Fixes: 41
Re: SvSIP? SIP Phone for Nintendo DS.
For username use your 7 digit sip id
For password use your sip password
Both should have been received in your activation email
That should get it to register but without the ability to specify an outbound proxy or STUN it is
unlikely that you will be able to get success behind a NAT router.
itsme
Could try port forwarding. I believe that these are the ports that Gradwell use.
SIP port 5060
RTP ports 49152 - 49202
YuJay
i got this working now Smiley
The DS i was using had a Bad Bad mic Smiley i just switched to my spare.
But if any one has a DS and would like to use it as a phone with plusnet this program dose work. just bear in mind the Nintendo DS Phat consoles have bad mics on some models.
