Straight to voicemail
IndiaBravo
Don't know if there's a problem today, or it may have been going on a while. I don't use voip too often, but had cause to get an incoming call and then got notified of 4 or 5 messages. Then called the voip number from my mobile and instantly got voicemail.
My control panel settings are voicemail enabled and delay 35 seconds, so nothing has changed there. And no forwarding.
Using a SpeedTouch 780 with phone attached and PSTN connected. But nothing, as far as I can tell, has altered there either (and incoming calls were working)
Thanks in advance for any info.
PS - outgoing calls on both VOIP and PSTN work correctly, as does incoming PSTN.
1 REPLY
IndiaBravo
Re: Straight to voicemail
Don't worry - all is working now!  Roll eyes
Very echoey line though....
