Stopping Emails When Voicemail Rec
mickycollis
Hi all,
I am getting a lot of emails Saying i have new voicemails.
Is there anyway i can stop these coming thru
Michael
Fixes: 8
Re: Stopping Emails When Voicemail Rec
It appears not (the only options available are with or without the message attached as a WAV file).
Unless using webmail, could you not set up a rule in your mail client to delete them?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
mickycollis
I could do, and just tell them to go yo junk..
itsme
There are 2 email addresses associated with the account. One found in My Details which is the one used if the phone goes off-line and any other account related items. The 2nd email address found in Extension xxxxxxxxx is where the voice mail notifications are sent to. Have you deleted the latter?
