Still no audio on incoming calls.(VOIP BETA)
ian007jen
Hi
I have tried both speedtouch 716wl and dect phone, Linksys Pap2t adapter and wired phone and xlite  softphone with the same results.
1.On calls from BT line to VOIP, the audio is only half duplex, ie caller cannot hear VOIP line.
2. On both hardwear devices the BT line CLID shows "unavailable"
3. Both devices are regestering every 25-30 seconds
Ian
1 REPLY
jakejohnson
Re: Still no audio on incoming calls.(VOIP BETA)
Hi Ian,
I have just replied to your post in another thread.
Hi ian007jen,
Sorry for the lateness of my reply,
We will be needing your extension number so we can run traces on your number to see where the CLID is failing.
Also, we would like to see your setting in Telephony> Configuration and Telephony > Expert Configuration.
Thanks,
Jake
