Speedstream BT200 Voicemail config?
MissionaryMan
Hi All,
I've just installed the above VOIP phone and it works like a charm.
What I'd like to do is configure the voicemail function on the phone so that the MESSAGE button works and communicates with the plus.net message centre. I'd like to get it so the message light indicates a voicemail waiting.
On the phone configuration, I've set my "Voice Mail User ID" to the correct ID, but I'm not sure what else to do. The message light doesn't  currently work, even though I have a voicemail waiting.
Any help would be much appreciated.
Cheers,
MM
Fixes: 44
Re: Speedstream BT200 Voicemail config?
I'm not sure that the PlusNet ( Gradwell ) voip system supports MWI.
If you look at the Gradwell configuration guides for Grandstream phones that support it  they say 'Set SUBSCRIBE for MWI to NO' , implying that it is not supported.
puddy
I had the same problem with my grandstream GXP2000 when the message light did come on (which was when it wanted) I found I had to re-set the phone to get it to switch off so gave up and set MWI off!
I setup my account to e-mail me the messge instead
Puddy
