Sony Ericsson C905
bone
Sony Ericsson C905
Hi, does anyone know if this phone can be used with the plus.net voip service using wifi? I am thinking of upgrading my mobile and the choices I have are N96, C905 or if I go to O2 the Iphone.
Any advice or info greatly received, ta.
Fixes: 41
Re: Sony Ericsson C905
A quick google seems to indicate that although the C905 has some SIP settings there appears not to be any voip client application so it looks like it wouldnt work with PlusNet.
Whilst voip worked fine on the N95, Nokia seems to have removed the voip client from the N96, see here
http://gigaom.com/2008/08/23/no-voip-in-new-nokia-n-series-devices-is-nokia-turning-its-back-on-voip...
but someone would appear to have got it working http://www.dreamstrikes.com/applications-series-60-3rd-edition-mobiles/13366-guide-make-voip-calls-w...
'fraid I dont know about the Iphone.
Hope that helps
RichSmol
You could use Fring though  Wink
