Sony Eircsson C510 + plusnet broadband phone?
pint
My mobile phone ( soney ericsson C510 ) has a setting for Sip conections, i assume this means i can use my plusnet broadband phoen on the C510?
therese three main settings listed in the Sip settings menu, these are:
User address
Proxy Server
Registrar server
Waht needs to go wher, and where can i find my password for plusnets broadband phone service, its been ages since i set it up on my router ( which woks fine)
and i cant remeber any of the stuff like username/password as for some reason my plusnet login deatails wont work
Fixes: 116
Re: Sony Eircsson C510 + plusnet broadband phone?
You're broadband phone details would have been emailed to you, the other settings should be as your router is?
Will Moderate For Thanks
puddy
The Sony Ericsson C510 can make Skype calls , plusnet VoIP is not Skype compatible VoIP service
did you get your phone from 3?
You could use fring to make VoIP calls but I don’t know much about fring myself or the Skype service
Puddy
Fixes: 43
User address
Proxy Server
Registrar server
I would guess that User address is your sip id
Proxy server is possibly natproxy.plus.net:5082 OR sip.plus.net:5060
Registrar server is sip.plus.net:5060
No, your normal login details wont work , you need your sip id/password as sent to you in the email
puddy
Quote from: MisterW
Are you sure that a sony Ericsson C510 can make direct sip voip calls without using fring and or skype software?
3 are pushing this phone to be used with skype service at present but I was unaware you could input plusnet settings to make voip calls
puddy
Fixes: 43
Having had a quick google, I think you might be right there Puddy. Sad
@pint, Can you confirm where you're getting the info on the settings from ?
pint
I bought the phone on O2 pay as you go, although its now on 3.
the Sip settings are accessed trough the settings menu, then conectivity then theres an entry for sip settings.
Ive tried fring, but the ericsson C510 isnt listed, with fring and alkl i get is something about only being able to use it for text not voice, which isnt much use if your trying to use a voice over internet thingy.
Fixes: 43
@pint,
I downloaded the C510 manual and can't find anything in there about Sip settings I'm afraid.
Any chance you can post some more details ( extract from your manual perhaps ) ?
puddy
Quote from: pint
3 sell this phone and now you have a 3 sim card call their tech support on 333 or visit their web site  I know it will work with skype voip they are doing all sorts of offer with skype 3 are even advertising you need never pay for a calls again
Puddy
