Siemens voip off line
puddy
I have had a problem with my siemens C460ip dect phone, incoming calls this morning went to voice mail all my other voip phones worked fine i.e. Grandstream 2000 Nokia E65 and N95 and speedtouch
I could make outbound calls using the Siemens C460ip today.
Gradwell had me switch the siemens off and then the router when powering on solved the problem
Gradwell said the siemens logged of the network about 10:55pm last night
so if you have a siemens phone you may need to check its working?
puddy
Fixes: 43
Re: Siemens voip off line
I've not noticed any problems, just tried my C475IP from the office and its answering fine.
puddy
Quote from: MisterW
great , but mines gone off line again
speaking to gradwell again about this problem , all other voip phones work fine just not my C460
puddy
farrin
Just tried mine now and it seems to be OK........
puddy
I have fixed my siemens C460ip phone not ringing on incomings by using the settings below-main change using port 5062 instead of 5060
Authentication Name:  ext number
Authentication password:  ?
Confirm authentication password: ?
Username:  ext number
Domain:  sip.plus.net
Display name:?
Proxy server address: sip.plus.net
Proxy server port:  5062
Registrar server:  sip.plus.net
Registrar server port: 5062
Registration refresh time: 180 sec
Network
STUN enabled: No
STUN server:  Blank
STUN port:  3478
NAT refresh time:  sec
Outbound proxy mode: Always
Outbound proxy:  natproxy.plus.net
Outbound proxy port:  5082
Voice codecs
VoIP Volume:High
Enable Annex B for G729: Yes
  Selected codecs   Available codecs
G711 a law
G711 µ law
G729
< Add Remove > Up Down   G726
Advanced Settings
DTMF over VOIP
Send settings X= Rfc 2833 X =sip info
Hook Flash
application type dtmf-relay
application 12
Listen Ports for VOIP Connections
SIP port 5060
RTP port 5004
Use random ports No
puddy
