Siemens C475IP VOIP configuration
Mike909
I've got a Plusnet account. Whatever I punch in, doesn't work. Can someone help me fill in these below? I'm trying to do it on the Siemens web configurator...
Personal Provider Data
Authentication Name:
Authentication password:
Username:
Display name:
General Provider Data
Domain:
Proxy server address:
Proxy server port:
Registrar server:
Registrar server port:
Registration refresh time:  sec
Network
STUN enabled: Yes    No
STUN server:
STUN port:
STUN refresh time:  sec
NAT refresh time:  sec
Outbound proxy mode: Always    Auto    Never
Outbound proxy:
Outbound proxy port:
Fixes: 41
Re: Siemens C475IP VOIP configuration
I would guess that it's pretty similar to the Siemens C460 , have you tried configuring as decribed in this post http://community.plus.net/forum/index.php/topic,57674.16.html
puddy
If its the same setup for the 460 details below.
go in to settings
ip Configuration
ip address type =obtained automatically
remote management
allow access from other networks = no
Telephony settings
connections then edit
Authentication = sip id/user name
Authentication Password = trial passoword
Confirm authentication password= trial password
Username= sip id/username
Domain=sip2.plus.net
Display Name = your name
Proxy server address=sip2.plus.net
Proxy server port=5060
Registrar server= sip2.plus.net
Registrar server port=5060
Network
STUN enabled=no
STUN server= leave blank
STUN port=3478
NAT refresh time=20 sec
Outbound proxy mode=always
Outbound proxy=nat.plus.net
Outbound proxy port=5082
Voice codecs
Voip volume= high
Enable Annex B for G729=no
selected codecs
remove G726
Click set
It may show as unregistered but leave for 10 mins when it will show registered
Dialing Plans
just set to no
Advanced Settings
DTMF over VoIP Connections
send settings tick in ref2833 and sip info
Hook Flash
application type=dtmf-relay
application signal=20
Listen Ports for VoIP Connections
sip port=5060
RTP port =5004
Use random ports =no
Click set
Miscellaneous
already setup
I hope that helps
Puddy
