Siemens 450 and 460 fix
puddy
Finally theirs fix for the 10 second silence problem on the siemens 450 & 460 ip dect phone.
It works for me, the fix was rolled out last Tuesday night (you dont have to change any settings its an auto fix)
if you still get the same problem try re-booting your router and phone
Puddy
Ps Thanks go out to Peter Gradwell for all his hard work
