Siemens 450 460 dect ip fix
puddy
PN still not heard back on the pre-dial code **620 which was being added for a fix on the siemens gigaset  range dect ip phones' that have no sound for the first 10-20 seconds
Any updates?
Kind regards
Puddy
puddy
Re: Siemens 450 460 dect ip fix
Still waiting for a fix
puddy
RichSmol
Your extension has been prefixed now. Are you getting a better experience now?
puddy
Not had a chance to try it out yet my partner goes back to work next monday so will wait until then.
Puddy
