Setting up BT Homehub by telnet
mortod
Have modified a BT Homehub 2.0 so that VOIP will work with other than BT. Using telnet to set up VOIP, but not sure what the various parameters should be. Have tried the following:
voice profile add
SIP_URI = nnnnnnn
[username] = nnnnnnn@sip.plus.net
[password] = ********
[display name] = (whatever you want as your name)
voiceport = COMMON
[abbr] =
and,
voice sip config primproxyaddr=nat.plus.net:5082
voice sip config primregaddr=sip.plus.net
voice sip config notifier_addr=sip.plus.net
config save filename=user
But the telphony settings page on the HH2 shows 'Service temporarily unavailable'. Any thoughts?
Fixes: 43
Re: Setting up BT Homehub by telnet
Try swapping the SIP_URI and Username fields around. I seem to recall some while ago a similar config arrangement with a Vovager 10v. In that case the username needed to be just your Sip Id.
mortod
Thanks for the advice.Sussed it in the end, by logging into the homehub and reviewing all the parameters that could be set, namely:
{bthhmod}=>voice profile add
SIP_URI = nnnnnn
[username] = nnnnnn
Please retype password for verification.
[displayname] = My Name
[voiceport] = COMMON
[abbr] =
[enable] =
[directorynumber] =
{bthhmod}=>voice sip config useragentdomain=sip.plus.net
{bthhmod}=>voice sip config primproxyaddr=nat.plus.net
{bthhmod}=>voice sip config proxyport=5082
{bthhmod}=>config save filename=user
{bthhmod}=>
zeb1801
Excellent stuff - works perfectly now - thanks!!
