Second opinion ref SIP password change....
Cathotel
Hopefully someone can confirm that either i'm an idiot  Smiley or there is a way to change the SIP password to something I want rather than the 'reset' option in the VoIP control panel which generates a random password?
The 'help' bubble suggests I can enter my own password 'here'  following the usual mixture of characters etc. but I can't seen anywhere to enter it?
I've tried several PC's and IE, firefox and Chrome..
Any help/confirmation would be appreciated..
Fixes: 117
Re: Second opinion ref SIP password change....
Nope, it was changed so you can only use the system generated ones.
Painful, but it's all we have..
Will Moderate For Thanks
Cathotel
Hi dvorak,
Sorry for the late 'thankyou' - much appreciated.
Can't understand the PN reasoning behind this change as I have to write it down (defeats the object Smiley ) and keep it if I install the software on another laptop.
Cheers,
Pete
Fixes: 117
I think it was foisted upon them by their suppliers, Gradwell.
knowdice
Yes it was a Gradwell thing.
Many people had their SIP passwords hacked and were then open to be charged for expensive calls being made by the hackers.
It is inconvenient but better than a large unexpected bill....
