Samsung Galaxy S 8GB Wi-Fi MP3 Player that makes free voip calls
puddy
My partner has just  been given a free Samsung Galaxy s mp3 player
I turned this mp3 player in to a VoIP phone that makes and receive free calls using the CSipSimple android app
It was easy to install because the wizard includes a Gradwell template already built in.  All I had to do was enter account name & password plus put a tick in to the right box for an incoming call ring tone currently the template on silence
The only problems is that it times itself out if not used after 1- 2 hours but all you have to do is deactivate the account then re-activate it.
Puddy
