SJphone Mac OSX multi users
zofbtb
There is a problem with sjphone not working on more than one user account.
The account it gets installed and configured onto first is ok but configuring the other user with the same details
gives a 407 warning and doesn't work.
I've managed a workaround (let's say the first user is john and the second jane)
copy
Users/John/Library/Preferences/SJphone
to
Users/Shared
then while in Jane's account, start sjphone, preferences, profiles and import the PlusNet_VoIP ini file
in Users/Shared/SJphone/Profiles
For completeness' sake you could also then do the same import for John after trashing Users/John/Library/Preferences/SJphone
so both users share the same profile
