SJPhone - Recipient can't hear me
jbatt
Hi
I've just installed SJPhone on the PC and using the pay as you go VoIP
Problem is: I can hear the recipient, however they cannot hear me.
Windows 7 FIrewall is off
Mic on the headset works
I've opened loads of port on the Draytel Router pointing to my local PC. Ports opened are
3478
5060 -> 5061
5082
8000 -> 8012
49152 -> 65536
Obviously I probably dont need all those ports open.
Any advice would be good
James
Fixes: 44
Re: SJPhone - Recipient can't hear me
You shouldn't need to open ports if you are configured correctly.
Make sure you have configured the Outbound Proxy correctly, it should be natproxy.plus.net:5082 , see guide here http://www.plus.net/support/phone/broadband_phone/setup/sjphonepc.shtml ( although it has the old proxy details ). You might also try the Proxy Usage as Always ( I think ).
Actually I've just thought .... What OS are you using ? there was some problems with SjPhone and Vista.
jbatt
Quote from: MisterW
Hi
Thanks for the reply. I have created a new profile and still have the same issue
I am running Windows 7 Ultimate 64Bit
James
Fixes: 44
Ah!, Windows 7 , you might find this thread http://community.plus.net/forum/index.php/topic,85221.0.html interesting.
I think the conclusion was that Sjphone was a bit troublesome with Win 7 , zoiper and 3cx seemed to work , but I'm not sure whether they were on 32bit or 64bit.
Hope that helps
