SJPhone Jabber settings
mickg6wci
Trying to install SJPhone on netbook. Error message says " Please specify your Jabber connection options" .On Jabber tab in options I think I deleted Server and other information on this page. What should be there ?? Could someone with a working setup please look at their settings and let me know what to put on this page please...........
Fixes: 42
Re: SJPhone Jabber settings
SjPhone is getting a bit long in the tooth now, but AFAIK it ought to work without configuring any Jabber settings.
TBH I would try using a more up to date softphone
Have a look at :-
http://www.counterpath.com/x-lite.html
http://www.3cx.com/VOIP/softphone.html
http://www.nch.com.au/talk/index.html
Hope that helps, post back with any questions.
mickg6wci
Many thanks for reply. I was only using SJPhone as this is the one that PN push and provide setup info for. Have used XLite in past, thought that was older, but will give it a go . Might try Fring as well that seems to work OK on my phone. Will try your other suggestions if needs be ....  Many thanks        ........................
