SJ Softphone
sharonadams748
SJ Softphone
I've been struggling to get his to work, for ages. I've followed the set up instructions, and I cannot get my softphone to authenticate. I've reinstalled the soft phone, confirmed my account details but I just can't get it to work. Help please  Huh
1 REPLY
RichSmol
Re: SJ Softphone
hi there, please could you list the settings you are using? Also, the details of any firewall or router setup you might be using. Do you get any errors from SJPhone as well?
cheers
Rich
