SIP settings on Ubuntu Empathy
Walter
I've not yet had any success in setting up  'Empathy'  the default VOIP client.
Has anyone managed to set this up? Could anyone help with these settings?
Dopublish ??  Port 0
Udp ?Huh
Use proxy  nat.plus.net:5082
Authuser  7377xxx
Authdomain sip.plus.net
The above settings produve 'Authentication failed'
Fixes: 41
Re: SIP settings on Ubuntu Empathy
Fixes: 41
Yes, you need to install telepathy-sofiasip and then it will work.
I've just tried it on my 10.04 virtualbox installation.
You need 7377xxx@sip.plus.net as your username, natproxy.plus.net port 5082 in the proxy and I'm not sure about the STUN settings since I dont  need to use it with my router ( its got a SIP ALG that works ).
Hope that helps
Walter
Thanks, MisterW, could you please help a little further.  I have changed the account as suggested, but my original settings for the other parameters don't connect.  I have also tried  Dopublish on and off, UDP on and off and proxy to  ' natproxy.plus.net port 5082' and none of the options connect.
It does try but comes up with 'network error' for an5 of the options.
Fixes: 41
Delete the account and start again now that you've got telepathy-sofiasip installed
It shouldnt present those options now when you select 'sip' for the new account.
Walter
Smiley
Now I know what 'MisterW' stands for, Mister Wizard.
Brilliant, amazing how did you get all that?
Followed your last instruction and hey pesto I dialled my Home number and it rang ok.
Many thanks for your sipport and support!
Fixes: 41
Glad we could get it working for you Smiley
